fpdizzle
Hi everyone,
I’ve have a T6 Camperking conversion and have discovered an intermittent fault with the sliding door.
On some occasions (but mainly on cold / freezing mornings) I blip the key which turns the headlights on and opens all the doors apart from the sliding side door. Both the outside handle and inside latch can be pulled open but the door won’t budge. It also will not open when using the key in the lock instead.
I've sometimes managed to get in the van and then lock and unlock the doors using the internal lock button on the drivers door which releases the sliding door, but this doesn’t always work.
I’m trying to figure out if this is an issue with the contacts on the door or something with the central locking system.
Has anyone had a similar experience and have any words of wisdom?
Thanks in advance.
Thanks in advance.
