Sliding door won't lock
Littleblackflash
Auto Engineer
VCDS User
I can lock my van using the fob and all the door lock as normal except the sliding door which remains open.
I don't have any errors on VCDS, and on the screen it shows the door closed. The lock buttons by the mirror switch also doesn't work. When I press the lock switch, it tries to lock but the locks bounce open again. I'm not sure if this is linked.
Any ideas why? Is there a way of testing it using VCDS?
A small squirt of WD40 has helped. The door will now lock and unlock.
I still have the problem with bouncing locks when pressing the button on door (next to mirror switch). Any ideas?
Hi
Hi I had the same problem and WD40 my locking mechanism and it operates cheers
