Sorry to bring up an old thread but seemed appropriate to post here rather than starting something new.
I believe I know the answer to this but wanted to check before I pull everything apart.
Similar to most, all of my electrics are stowed under the driver and passenger seat. I have run all my 12v cabling to the rear of the van spurring off where needed for tap, fridge, lights etc etc.
My issue is when listing all my outputs I overlooked something and have forgotten to run a 12v supply to the CO monitor. Does this require its own dedicated 12v supply or can I common this up with another 12v supply, I have listed other 12v supplies below within my installation;
12v LED lights (Don't want to run it off this)
12v Fridge (Don't want to spur from this)
12v gas valve solenoid kit (Is there a potential to spur from this to feed the CO monitor?)
2 no. USB outlets
If I have to pull the panels again and open up all my conduit I can but just looking for other options prior to this.
Thanks for any help or confirmation that I need to pull the panels off again.
