I just wondered if this was something that someone else may of seen before. Any idea on the 3 pin plugs?Take the panel off and trace the wires back.
I’m guessing they are 12v but I’ve never seen anything like that beforeI just wondered if this was something that someone else may of seen before. Any idea on the 3 pin plugs?
Thank you. I’m a bit new to all this!I’m guessing they are 12v but I’ve never seen anything like that before
Other than a led on the switch coming on nothing I can seeNot seen that type of plug before either
Anything happen when you flick the dash switch ?
That’s exactly them? Do you think I can change them to normal cigar type and maybe usb’sthey look like a knock off of the durite trailer connectors what was the vans previous life
First thing I would do is get A multimeter on them and see if that dash switch is powering them up the have a look at the wiring and see how they are wire and to where. I can’t see why you could not change them out for what socket type you want. Check for fusing to and see what thay are rated at.That’s exactly them? Do you think I can change them to normal cigar type and maybe usb’s
Thank you! It’s just to keep the kids happy for now long term project, lots of pennies to save upFirst thing I would do is get A multimeter on them and see if that dash switch is powering them up the have a look at the wiring and see how they are wire and to where. I can’t see why you could not change them out for what socket type you want. Check for fusing to and see what thay are rated at.
I’m assuming it’s all wired to the ‘gubbins’ under the passenger seat, looks like a relay with a red led in it and a black box which I’m guessing is something to do with controlling v the charge of the leisure batteryThey resemble battery charging sockets of years gone by that were fitted to the ancient fire appliances of the 70’s & 80’s when I had a proper job.
Post a pic of what you have under your seatI’ve got some fast learning to do
Dirty boy! Inciting up kilt photos.
