Can't have too many "how to" threads with pics, so here goes...
Quick steps to remove door card (EDIT: this is the driver's side, but the passenger side is exactly the same steps, just fewer connections)
1. Prise off trim on handle on door card (little slot to below rear to put a screwdriver in)
2. Prise up and remove window switch panel (lever up from front edge and work backwards). Remove three connectors (use small screwdriver on clips - the green one can be tight, the others are easy)
3. Then should find two torx screws inside handle, one torx in middle of door card, and turn the two knobs underneath the door card (yes, right down underneath) 90 degrees with a 10mm spanner to match cutouts.
4. Pull from bottom of door card, working up each side to ping off the three clips each side.
