Can someone please give a little advice about how much dodo mat is needed for a tailgate door, and how to install, there’s loads of really good vids on the rest of the van, which has made this easy, any hep for a newbie, would it much appreciated
Can someone please give a little advice about how much dodo mat is needed for a tailgate door, and how to install, there’s loads of really good vids on the rest of the van, which has made this easy, any hep for a newbie, would it much appreciated View attachment 128862View attachment 128863
There’s only so much you can apply through the voids. Most components come out and refit easily so don’t be shy about removing some bits to make it easier to apply it.
I ran a led feed to tailgate recently and had to pull some of the sound damping mats out to get room, and I don’t even have full thermal insulation so the voids are not really filled.
Thanks again for your help everyone, managed to remove the panels, and remove the factory fitted foam and ended up using the last nine sheets of dodo on my tailgate, bit tricky but I think it turned out good.
I have gone way over the recommended usage of dodo mat, I’ve covered everything I could get my hands to, 60 sheets in total so far, still have the floor to do, I haven’t noticed any difference thankfully, did cross my mind tho,
