Speaker upgrade kit
Sems
Hi
Speakers have a very tinny sound , I’m not looking for anything fantastic but can cope with the current sound
Has anyone had any experience with this set up or any other recommendations appreciated
I would consider the Alpine SPC 108T6 a bit more expensive but with a 20cm woofer, that will most certainly sound better than the JBL kit.
I’ve had a Quick Look , can only see kits where the tweeter goes in the pillars , I’m looking for simple plug and play into old tweeter location on dash
I’ve found these in same site but more expensive with bigger woofer but ain’t heard of the make
I fitted the Blam kit from SCR. The speakers are lower impedance so they're a better option if you're still running the standard head unit. The Alpines really should be amplified.
Just had a look and it seems SCR don't sell them anymore, the Feelart seem to be the replacement. My tweeters came on a custom 3D printed plate the fits in the factory position under the grills, I'd assume they're still doing that.
Here's the JBL kit showing the tweeters mounted in similar plates to mine:
I also owned a T5 some years ago and i was very satified with the multivan 20cm upgraded speakerkit , its an OEM part and not expensive at all....great value for money
