Squeaky rib swivel base driving me nuts.
DCC
Does anyone have a fix for squeaky rib offset swivel base? Only really squeaks with the weight of a passenger in it, drivers side also squeaks a little but nothing as bad as the passenger side.
Is it loose ?
Mine has had similar, stripped and rebuilt and all ok since.
If not, check where the plastic hits the base - recently mine has been making a racket but not loose or anything, worked out it was the trim on metal and an offcut of carpet between cured that.
Is it loose ?
Will take it out today and go through it
Grease your nuts?!!
I do this daily, never helped with squeaks mind
Little update for anyone else who maybe experiencing similar issues.
The 3 sets of cone shaped locating stops where causing a lot of the noise so greased them and stopped he majority of the squeaks. I also removed the swivel from the vw base and stuck some fabric pads in between the base and swivel and now have a totally silent pair of swivel bases.
@DCC I have just fitted these and getting this issue.
What grease did you use on the pegs and what kind of fabric did you use between the seat swivel and the base?
I used white lightning bicycle grease but any grease would do.
Sticky back fabric pads in between the base and swivel like you would find stuck on the bottom of lamps etc
I fixed a similar issue recently, it turned out that a piece of the frame had bent slightly and was rubbing against another piece, moved the offending part a mm or 2 and it stopped rubbing against the other piece, hope this helps
