Download icon
SSP 820433 EA288 2.0L Derv Engine T6.1? 2024-02-01
No permission to download
need to find a pdf download for the SSP 722 now.
Greetings from Hong Kong,
Here is the SSP 722 PDF file I found containing the EA288 Commercial (EA288 Nutz) Diesel Engines (66kW DNAC, 81kW DNAB, 110kW DNAA, 150kW DMZA)
They are used in Mono Turbo TDI and Twin Turbo BiTDI T6.1 models after 2020.
Those new EA288 engines are very different from the EA288 series engine used in pre-2020 T6.
For example, old T6 BiTDI CXEB engine used Delphi system solution (DCM 6.2 management ECU with 2000 bar dual-piston HRP738 high-pressure common rail pump and solenoid valve HRD372 fuel injector)
on the new T6.1 BiTDI DMZA engine used Bosch system solution (MD1 CS management ECU with 2500 bar single-piston CP4.1 (CP4E/R45) high-pressure common rail pump and solenoid valve CRI 2-25 NC fuel injector)
Both engines have the same power output (150 kW at 4000 rpm) and roughly the same power band (older CXEB have 150 rpm more max torque band)
All the changes are for the new DMZA engine to have better emissions on paper.
Edit : Turns out I can't upload the pdf successfully due to the server file size limit
Here is the temp download link instead: https://file.io/3nbFrUJvt3PE
