Wanted Staggered 20’s in bronze/anthracite
RT76
Having bought some new knees for my Caravelle, I thought it only fair to start looking for some new sneaks for the summer.
Is anyone selling or know of anyone selling a set of bronze or anthracite alloys.
Don’t need the tyres, as I will no doubt buy some new ones, unless they are Michelins or similar on them already.
Looking at 8.5 fronts and 10 rears, although may need some advice on the ET for the rear as I don’t want to foul the sliding door cards.
Many thanks in advance
Hi there
I have the same set up as your looking for with 10s on the rear and no fouling of door cards but close- look forward to pics!
Looking at 245/45 20 for the front and 275/40 for the rear, I can live with a 1mm difference front to back!
got a brand new set of navis ludis and tyres? £1000 in silver and 9j all round with 20mm
spacers for rear
275/40 is pretty likely to foul the Caravelle door card on the back with any offset, but the higher offset the better.
For example; Velare do their 10” wide wheels in 38 and 45 offset, the 45 to help clear Caravelle door cards, the 38 won’t.
How low are you?
Won’t be silly low - I bought the H&R coilovers from Ben, on here.
Driveway means I can’t go too low, so maybe 80mm from normal.
Long term aim is to go for air+, but for now this is a temporary solution to my needs for reasonable height in the winter and a bit more sportiness in the summer.
80mm might be too low for 245/45 front tyres, you might get some rubbing. Remember that the Caravelle is 20mm down as standard, so a normal 80mm drop will be 60.
That’s through shorter stock springs though, isn’t it, so yes, I’ll be 60 lower than stock Caravelle, but 80 lower than stock transporter.
Looking at 8.5 fronts and 10 rears, although may need some advice on the RT for the rear as I done want to foul the sliding door cards.
Not staggered but a good price
You’re right, it was late when I looked at it, I thought they were linked by the seller! ‍♂️
Reactions: Bav
If you’re still looking, these have just been listed
5x120 20” riviera rv177
9j fronts with 255/35/20 tyres
10.5j rears with 275/35/20 tyres
tyres have covered 800 miles
I’m about to have some calibre cc in anthracite for sale, that would need refurbing to be mint, might have 2x ok crossclimate tyres on them (other two worn out)
