Stance Proline Rear Cup.. Didi i fit it wrong, Knocking
Schooke
This weekend i fitted stance prolines to my T6.1..its been traumatic!
I did fit new drop links, top mount bearings, rear spring seats etc whilst i did it. On the test drive the front seems good, but the back has a little clonk. The sping is seated correctly on the bottom, the damper is wound down to its lowest/shortest setting and the spring is set at half the available hieght (which will need to go lower). The only thing i can think is when installing the upper cup, they dont sit tight/snug, they can go side to side slightly. Did i miss installing anything there? I have put any rubbers or anything in that part as what came out was too big.
Any help please.
On a T5 & T6 the adjuster is too tight a fit to slide over the post on the chassis. Normally it needs a file of the post to allow the adjuster to fit snuggly. Did you do this or is it possible it's not slid over the post enough (flush with the top)?
