Standard Interior Lights
T6180
T6 Legend
I want to add a couple of standard style interior lights above the bench seat and in the rear section.
Would this be easy to do if I bought the clips with wiring from somewhere and just spliced them into the original wiring?
Would this cause any bulb lights on the dash or any other issues?
Many thanks
Mark
I have a std one going spare if you want it.......you pay the postage and you can have it.
Would cause no issues and should be pretty straightforward to do, if you are adding a couple then think I would make them all LED so your not increasing the load on the circuit
Cheers @Pauly I've got LEDS in now and some spares, do you know where I can get the clips with enough wire so reach from the original fixings to to opposite side?
I got plugs and crimps for the light fittings if you need them, send me a pm if you want some
