Hi
Does anyone know if it is possible to alter the min voltage level in the battery that causes the engine to restart when that point is reached? I havent worked out what that is currently set at mind , but I would like to increase it by a volt or 2.
Reason, when the voltage on the battery drops below a certain point on a restart the amps reset themselves and go silent for a time, at 10.1 volts everything keeps playing just fine but I'm unsure how much lower I can go, as the amps have a working voltage of 11 to 16v I would ideally like to set the restart point so as it never drops below the 11 volts point.
I'm currently looking into fitting a 2nd battery, but this would be a heck of a lot cheaper if possible. No wish to turn off start-stop as now that I'm use to it, I like it
