Hi I have a set of very good condition steel wheel centre caps for 16, 17 , and 18 inch amarok steels. There £30 posted anywhere in the uk mainland. These will be packaged correctly too.
Put a small blob of clear silicon mastic or similar one or two of the wheel nuts, (Clean them first) Then push the centre caps on.This can easily be overcome with a strong pull if you want to remove them, but will stop them working their way off over time. The mastic can be removed easily and a fresh blob put on when refitting.
