Chrisab
Hi all. Just need some advice. I bought a t6 California about 6 months ago and noticed the steering had some play in it when I move the steering wheel about 10-15 mm the front wheels don’t respond. I have checked the steering shaft in the cabin that all moved at the same rate as the steering wheel so that part looks ok. I then changed the rear springs for harder levelling springs as it had the usual rear sagging about 30mm lower than the front as I thought this might help with the play but no change on the steering. I think I might have found the problem I have been advised it’s looking like the intermediate steering shaft but don’t want to spend approximately £450 parts and labour if it’s not that. Has anyone has the same issue. Thanks
Chris.
Chris.
