Hi all. Fitting a sterling b2b charger and the manual states both the aux battery and b2b charger should be seperately earthed directly back to the starter battery (not via the chassis). In my case the aux battery and charger are both at back of the van so would mean running two separate earths which seems a bit of a chew. If its best not to use the chassis then fair enough but surely I could get away with running one earth between the batteries and take the charger earth from the aux battery? Presumably this is due to volt drop? Has anyone connected up differently to how Sterling advise?
I’m thinking I run one earth between batteries (slightly over sized), earth the charger to the aux battery and for belt and braces connect the aux battery to the chassis too which should solve any major volt drop issues?
