Its been so difficult to find someone to fit the floor rails for my California bed I decided to fit them myself. So after buying brackets and all the kit and after much procrastinating, putting off the job, I decided it was time to get it done.
SO after about 1.5hours under the van removing bolts, clips etc to get the aluminium heat guards off from over the exhaust I am stumped.
Firstly I came upon this, holding the handbrake cable, there is no way the black plastic bit slides out of the metal bracket, which is held to the chassis with a rivet:
So I decided if I could drop more of the plastics then I might get some wriggle room to get it off another way.
Trying to get the plastic trim off under the driver seat I can across another of VW's little traps to make things difficult.
This little bugger. I cant get a grip on it with anything to 'unscrew it', or bend the little tabs that grip the thread:
Why the French connection UK have VW made things so awkward. Im sure converters must just break bits to remove the trim from underneath the van, but I'm not happy with that.
Well I guess its another couple of hours to put it all back on.
Just venting frustration.
