Subframe Alignment
Van Buddy
204 Kombi 4motion 2017MY
Hi
Is there a set procedure for aligning the front subframe after removal if alignment bolts have moved ?
I was thinking of measuring the wheel base, 3000mm, and setting offset/inset equal each side to the rears.
Bit difficult to see up through the bush in the subframe but good idea.
Thanks for the torque settings.
Going back some years, I had a vel T5, which scrubbed a front tyre (from new), it turned out that VW had manufactured/assembled it incorrectly, and the dealer had to send to Germany for some new bolts to resecure the subframe. It was diagnosed via the dealer using his 4 wheel laser alignment. But I'm not sure if he used the laser alignment to put it back together.
I wouldn’t worry to much about the alignment of the subframe, as it will only fit within manufacture spec, But would have a 4 wheel alignment done, as soon as poss.
That is proberbly becouse the wheel alignment was out of tolerance. There is a tolerance between the subframe and the mounting points on the chassis, this is probably no more than 2mm.
I'm struggling to remember....... but I think either the bolts where single-use only; or shear studs. So the dealer had no choice but to get some new ones,......... or maybe even corrective studs. I'm struggling to recall, but I certainly got the feeling I wasn't unique.
I think on the T5 , the subframe was completely different on a Vel compared to a Van, not that it's relevant to this tread.
The wheel alignment has been checked many times and was spot on every time.
Main dealer has had the vehicle back 6 times and now finally admitted the subframe was mis-aligned from the factory.
They could well be stretch bolts. I dont know for sure.
Thanks for the education; I'd never heard of stretch bolts before; and now after a few googles......., I'm educated as to the risks of re-using them :thumbsup::)
Perhaps the VW dealers laser alignment system is more than just a wheel alignment system, but also a whole-body/suspension laser jig system to deal with accident damage as well???
Not Heritage Automotive Bristol, they call another company in.
