This may be a silly question, but has anyone put SWB units in a LWB van? My thought was that with SWB units I could have a sliding door on the driver's side and still be able to use it.
The lwb is only around 400mm longer than the swb so if the swb units took up the whole length then you’d only have around a 400mm gap. Hope that helps.
We saw a van like this when looking at options though it only had the slider on one side. I think you could get in but it would be tight. You definitely could rotate the drivers seat comfortably though.
