Swivel seat base and heated passenger seat
JDTech
Got a heated passenger seat recently, also have a swivel base just trying to work out how to run the cable to stop it twisting up etc. Anyone done it before ??
Is the seat a double or a single? If it’s a double then the only way is to connect/disconnect externally. If it’s a single then depending on the swivel used you can usually feed the cables up through the centre
I've got a double swivel, Sorted it, will post pictures later
Nice one. Keen to see what you've done.
I've got my solution all mapped out, just need to fit it. You might now show me something better!
Hi all,
Hope you can help, trying to fit a double swivel in my t6.1 which has heated seats.
If I just disconnect the wire will I get an error code or will it be fine?
Many thanks
If its just the heated seats you'll be fine, if you've got an airbag you can disconnect but don't turn on the ignition until you reconnect.
