BT's where did you buy your rear floor mat please
This is the only picture I have got. I would go for the factory swivels. The aftermarket swivels raise the seat height by quite a bit and means if you are on the short side you may struggle.
Thank youThis is the only picture I have got. I would go for the factory swivels. The aftermarket swivels raise the seat height by quite a bit and means if you are on the short side you may struggle.
Yes, this is a Factory Kombi with a 2+1 (the 1 removed). I suggest there is not enough knee room for two adults sitting opposite each other.Thank you
Is this a Factory Kombi with fixed rear seat bench seat as the distance between front and rear seats looks different to Insert Coin ??
Thanks, as it is for 2 adults in the front and 3 small children in the rear it's a worthwhile factory option considering the low cost....thanks for all your repliesYes, this is a Factory Kombi with a 2+1 (the 1 removed). I suggest there is not enough knee room for two adults sitting opposite each other.
