T 6.1 Tyre Sensors? not fitted with Nav Infotainment ?
shaun03
Hi i had a flat tyre the other day on 23 plate highline conversion T6.1 but had no warnings on dash - and according to tyre man there is not a symbol for it anyway- its fitted with the Nav media info player - so looked into settings as mentioned on here and no sensors fitted ? is that correct or is a software/program issue now?
thanks in advance
I have a 21reg Highline, definitely no tyre pressure sensors fitted ( 4 less things to go wrong !!! ) I expect yours is the same.
Tpms can be passive and done by abs or active and done with sensors or not fitted at all (although quite rare on a t6.1)
Mine is also a 21 plate highline and had not TPMS as it was an option when new. I have switched passive on using vcds though.
