Ah also !!!
you have the standard T32 springs (that i upgraded to on the last van)
and the T32 OEM Sportline springs - which are 30mm lower than the standard springs. (eibach)
more info:
EIBACH PRO LOWERING SPRINGS 30MM VW T5 & T6
Eibach PRO Lowering Springs 30mm VW T5 Transporter & Caravelle 2003-2015 & VW T6 Transporter & Caravelle 2015 onwards
Lower your VW T5 or T6 by 30mm with our superb Eibach PRO lowering springs.
Eibach are renowned around the world for their excellent quality so you can be sure that you're getting the best with this kit.
Eibach springs are engineered and tested for optimum handling and designed to work with standard dampers, enjoy great ride comfort and a sporty lowered look with these fantastic springs.
Be sure to select the right option for your T5 or T6 as there are two options depending on the weight of the front of your vehicle.
VW T5 Transporter & Caravelle Models:
VW0993 – 4cyl diesel engines excluding DSG and Bi Turbo models.
VW0995 – 4cyl Diesel engines fitted with DSG or Bi Turbo, 5cyl diesel engines all models.
VW T6 Transporter & Caravelle Models:
VW0993 – Maximum Weight on front axle - 1550kg
VW0995 – Maximum Weight on front axle - 1710kg
*The T6 choice requires you to check your vin plate located in the engine bay to gain front axle weights*
Please select from the drop down box below the kit required for your vehicle.
Fitment:
VW T5 Transporter, Caravelle & California 03-09 and 2010-2015.
VW T6 Transporter & Caravelle 2015 onwards.
The VW T5 & T6 factory specification Sportline models have these lowering springs as standard.
When having new or up-rated suspension fitted it's advisable to replace such things like the rear coil spring mounting cups as these can sometimes be worn. When uprating your suspension, using old worn parts can sometimes cause vibration or knocking from the worn components so we always advise to replace these parts at the same time. Please Click Here for the genuine VW OE rear spring cups.
Please note we do not offer a fitting service for 4Motion models. If you have a Sportline model your vehicle will already be lowered by -30m.
All specified lowering rates may vary approx. +/- 10 mm depending on vehicle standard specification, options, tolerances & age. For example camper conversions, carrying more or less weight in the rear.
*After any adjustment to a vehicles ride height it is recommend the vehicle’s geometry is checked and re-aligned using suitable equipment. Failure to do can result in excessive and uneven tyre wear and in extreme cases even affect the vehicles handling. Please note Vanstyle do not offer an alignment/geometry service and alignment is NOTincluded within the Free Fitting Service.*
Eibach PRO Lowering Springs 30mm VW T5 T6 - Vanstyle
