For Sale T32 brakes, calipers, Nutexa discs
Fromow
Back up for sale due to deal falling through.
T32 complete front callipers with hardware, hoses and dust shields.
Nutexa front pads with 5k miles use
340mm Nutexa front crossed drilled and grooved discs with 5k miles use
294mm Nutexa rear cross drilled and grooved discs ONLY with 5k miles use
£600 collection only from Kent due to weight
Are the rear discs the same size as the standard small rear discs or standard small front discs (and the standard front Caliper can be used on the back) or standard large rear discs?
My understanding is all the rear discs are the same size (294mm) across all models.
As far as I know you can’t swap callipers front to rear due to bolt pattern, callipers offset, size and handbrake
