I’d suggest speaking to Steve at CRS Performance. He will be able to advise if this is a suitable solution for you and potentially supply you with the parts.
Depending on how low it is on the rear you may also need some spring distance spacers as well as T32 springs ? we do have them in stock . The trick here is more about making the spring longer NOT stronger , the stronger the spring is the more harsh the ride will be !!
