The Van Cave is now offering KW variant 1 suspension for T32 transporters for just £1205! including VAT, plus fitting.
Yes, as a number, that's a lot of money, but at that price it is so much better value than virtually all comparable competition. For example, it's almost £500 less than the B14 komfort kit. Sadly, there is one downside, there is no current stock and new stock won't be available until Late Feb, but once it comes in I'll be keeping stock of these at all times because I have a feeling that at this price they will be hugely popular!
What is the KW Variant 1?
It's a TUV approved, genuine coilover kit, with stainless steel threaded body front shocks. These use trapezoidal cut threads for strength and ease of adjustment. They offer amazing ride quality and are specifically designed so that the ride quality doesn't reduce even at their lower ride height settings. Lowering from approx 35-65mm is possible with this kit. Note that these numbers are always approximate and can vary from van to van.
If you're interested in this fantastic product at this fantastic price then please get in touch via forum messaging or by emailing chris@thevancave.co.uk and we'll discuss it further. No deposit will be required for any bookings, but it will be early March before these will be available for fitting.
If you're thinking 65mm isn't quite low enough for you then don't worry, you can still make use of this kit, I have a trick or two to get you up to 80mm down if that's your thing. Or I have other options available for that too.
All the best folks,
Chris.
All the best folks,
Chris.
