Ok so I have a T5.1 with barn doors
central locking via remote fob (or key) works fine including the barn doors
I have fitted the switch to lock the doors in the drivers door but when I press it is locks the door and then just unlocks it again.
same thing happens doors lock and unlock instantly if I enable the doors to lock at 10mph in vcds.
Other 3 doors show up and open/closed correctly in vcds but I can’t find anywhere that tells me the status of the barn doors - perhaps the long coding is wrong but having worked through the documented options it looks ok.
finally 4 faults keep returning to module 9 and they are all about implausible signal on the 2 front doors, the sliding door and the “lid” which I don’t have (although that could be a red herring)
any ideas?
any ideas?
