T5.1 Removing silver strips on grille.
Carl1974
T5.1
I’m looking at replacing the silver inserts on the grille for green to match the strip below, I’ve noticed that some of the silver has started to flake. I purchased a roll of green but how would I fit it if the silver strips have clips?
I had the same (mine were red but I wanted them black) - you can gently unclip them and then I sprayed with plastikote….looks great! Failing that, your green strips might stick on top?
Thanks Dan, I tried putting a piece on the top to see what it was like, close up you can see the silver underneath.
