Gilbeynut
Good afternoon all.
Hopefully this should be a simple question for those in the know. Since completing a long journey on Thursday, I can hear a rubbing noise coming from what sounds like underneath the front nearside of the van. It's only present with the van under load i.e. it's silent when coasting with the clutch depressed. Whilst doing a general visual check of the drive shafts, in an attempt to hunt down the noise, I happened to note that there was a lot of lateral play in the nearside drive shaft i.e. movement of the shaft in and out of the gearbox. There is none in the offside drive shaft. Am I right in assuming there should be none, and hence I have a CV joint/Drive Shaft that needs replacing? It's a 2004 1.9 (AXB) T30 with a 5-speed manual. Thanks in advance for your help.
