Just to let you know I had the 30mm lowering springs fitted to my 2020 T6.1 California. The rear was too low and the van sloped to the rear. VW would not do anything about it - however I have just received an email from Eibach who have admited they are aware of the problem and have just received TUV approval for fitting the lowering springs to the front BUT leaving the original factory fitted springs on the rear. They say this will result in a neutral rake bias...... VW are refitting the original rear springs back on my California this week......
The Camper /California's always sit low on the rear with the conversion weight , Why VW would sell a spring that allows the rear to sag i cant imagine .
Caution with a lot of product that Doesn't have T U V approval because these parts could have been made for a Private label supplier and the prerogative is on the private label Supplier to T U V approve it and Not the spring supplier.
The comment from previous Eibach employee regarding TU V is spot on and this highlights a few issues we have in UK where T U V isn't a recognised standard . There are lots of product sold in UK that don't have TUV but more importantly wouldn't be able to get approval. So Be careful out there ??!!
The T U V test mainly checks the lowering ability and safety of the vehicle at the height that the manufacturer claims , IE if a vehicle is lowered too much the wheels can fowl the inner wheel arch , this would be a fail "!!! TUV don't check Shocks as this normally doesn't affect the height and therefore cause any touching.
