T6.1 Bulb failure disable VCDS help
GazzaC
Good Evening.
I recently purchased a 2024 Transporter. I have changed the dipped and DRL bulbs for LED bulbs. I now have bulb failure up.
As it is a newer van, when you go to 09 CENTRAL ELECS you cannot do any coding to remove bulb failure. I spoke with Ross Tech and they say there is a chance to do it through adaptions. I have looked and it is all German. I have searched everything under LIGHTS or Lichter, and it offer a hugh amount of varients. I can see some have DTC next to them and I would assume I set them them to 00. My question is, does anyone know exactly which ones are for DRL and Dipped beams?
Many thanks
Gary
