T6.1 buzzing sound
hayesie
Hi
Can anybody help I have a wired noise form my t6.1 it has been back to the company I got it from they are not interested as don’t effect the drive and no fault codes .
Just wondering what it is ,it does when unlock with fob and randomly once unlocked sounds like coming from drivers inner wing / engine Bay Area .
Any help much appreciated
It's the fuel pump priming I suspect, the normally happens as you open the driver's door.
My 6.1 makes a number of noises under the bonnet as it either prepares for a drive or prepares to shut down, including sounds like valve actuators.
Ok great thanks for reply just wired as others don’t seem to do it .
Lift pump priming, EGR going through a cleaning cycle, they make all sorts of weird noises...at least mine does and the ones I test drove did (all 6.1's)
If it seems excessive grab a clip and put it on YouTube or SoundCloud or similar and link it here, then those of us with 6.1s can tell you if it's similar or wierd :thumbsup:
