T6.1 Cargo area LED plugs?
TristanH
Good morning all.
I have 2 , diagonally opposed LED lamps in my van, I'd like to add more to give more light and balance the look of things.
I have the lights, anyone know where to source the correct plugs?
Please.
Hi Tristan. Which connectors? If it's the same as the step lights I have some in the garage you're welcome to. Can you get a picture of one? These are the ones i have1000009565.jpg
I'll have a look at a spare step lights I have in the morning and let you know. Certainly looks similar
If you're adding them to the standard wiring for parked up use remember that they will time out (20 mins as standard, sometimes 1 hour if factory fit LED cargo Transporter)
On a T6 you can alter the time delays with something like VCDS up to about 2 hours; so far I don't think anyone as found where this setting is on a T6.1 (as I'd love to do it)
"Standard" courtesy wiring is three wires: timed out +12v feed, one negative feed to the door switches, one permanent negative feed.
Some cargo wiring only uses 2 of those as there is no "always on" switch on the lights.
