T6.1 Centre Bore protrusion?
Stu Hutton
Hi all.
Does anyone happen to know what the Centre bore protrusion / depth is on a T6,1 4Mo?
I know the bore is 65,1 but don’t know how much it sticks out.
Looking at wheel spacers. H&R hub centric only come in 3mm,5mm shims then 15mm & thicker.
Doing the maths i am probably only going to have around 14mm gap between the rim and sliding door card (California) on the wheels I’m eyeing.
I’m guessing there’s no hub centric 10mm as the spigot protrusion might also be 10mm but I’ve seen some Darkside 12mm hub centric spacers and wondering if they would fit.
The Darkside website asks that you measure the spigot protrusion before ordering - I’m in bed with manflu so can’t really go out and whip a wheel off for a reccy.
Hopefully someone knows & can help.
Thanks Stu
I can’t remember exact measurements, but it’s somewhere around the 12mm mark. They can vary slightly, so it’s always worth measuring to be sure when the man flu wears off.
You can’t fit a 10mm hub centric spacer for 65.1mm centre bore wheels, but you can if the wheels are 72.5 or 72.6mm centre bore.
I was looking at the same issue and measured the spigot protrusion - it is around 12mm. I also checked the wheels I was wanting to use and they have a chamfered inner edge of around 6-8mm, so therefore once even thin spacers mean the wheels will not be supported by the spigot.
