T6.1 dash lighting
tommy_t6.1
Builder
I've got a t6.1 startline with no auto lights.
One issue I have, and have had for the 4 years I've had the van, is that the dash lights dim to off when the outside light level drops. As it gets darker you can see the dash lights dim down. I get why it does it so you remember to out your headlights on, but it's annoying when it's not dark enough for headlights but the van switches the dash off. Ir going under tree cover or through a tunnel.
Is there a way to disable this function? Or even better, use the light sensor as a work around for auto lights?
I would guess the dash lights can be tweaked in T6.1 because the cluster has the adaptation channels mentioned in the post below:
Thankyou for that! Although it's burnt my head out trying to understand it! Haha I'll figure it out in sure!
Reactions: mmi
