As per title 20' T6.1 with Kiravans double swivel fitted by converter
(who are being less than helpful as I bought S/H & don't want to know)
I've removed the swivel base to reinstate the factory seat heating (as prefer that to the swivel) but can't find the incoming wiring connectors for the heating anywhere under the rubber floor, just all the through connectors that should be on the black plastic frame attached to the seat base framework.
They are the 2 & 3 pin plugs to connect to these.
This was taken quickly after I put the seat back in place as I needed to use the van.
Obviously all the other wiring is just loose in the bottom in this pic, but I lifted the rubber floor across to the hand-brake but couldn't see the other end of them, & am just wondering if the converter has removed an accessory loom/branch? & what should I be ordering other than the black multi-connector bracket.
Also any ideas on how/where they have hidden the connectors possibly?
Any ideas, or photo's of what should be there would be greatly appreciated
I believe these are what should be there (I copied this image from another thread but it is a T6 I believe)
Swapping a heated double passenger seat for a heated single passenger seat
Hello, just joined the forum since purchasing a 2016 T6. I plan to swap the heated double passenger seat for a heated single captain seat which I have sourced in matching fabric. The single seat is fitted with a single 3 core black plug, but the double seat is fitted with a matching 3 core black...
www.t6forum.com
