The only way you could do this is to connect them to the ambient lighting circuit instead of the courtesy circuit.Evening all.
Just got a new T6.1 & while moving it across the yard with the rear door open, the interior footwell lights stayed on, and I liked it!!
No glare on the glass. Is there a way of keeping them on without driving with the door open?!
HardwireCheers.
Is that a hardwire job or a coding job?
Great, Cheers.I'll be hopefully getting stuck into it at the weekend. I'll let you know.
Did you ever do this ?I'll be hopefully getting stuck into it at the weekend. I'll let you know.
I added another set of lights to the ambient lights. There is a kit you can get from Travelin Lite that I wired into the ambient light circuit.Has anyone done this? I'm keen tk keep mine on when driving.
I was looking to do the same, got any pics or your install please?I added another set of lights to the ambient lights. There is a kit you can get from Travelin Lite that I wired into the ambient light circuit.
Perfect thanks, did you cut another hole in the trim as per the OEM one?This is the only image I have, the lights can be changed between the red, blue or white options. It was very easy to do, they dim down with the rest of the dash perfectly.
thanks !Sorry I’ve only just seen your reply. Yes I did have to, I just trimmed out a section next to the existing light.
