T6.1 Fuel Tank
Jippy Yates
My fuel gauge is showing full and I suspect the float/sender is stuck. Can I access the sender from inside the van through an inspection hole or do I have to drop the tank? Thanks.
drop the tank job.
try running the van low on derv.
then get the front up on ramps and bang the bottom of the tank with a rubber mallet?
the adblue tank is there too, go get the right tank.
Just for information, I ran the tank right down to nearly empty. I then refilled 3/4 and the gauge worked. Must have been the float stuck and caused probably by overfilling. I now stop filling on the second click of the pump and all has been good. Thanks for the help.
