T6.1 Genuine towbar wiring kit not triggering alarm
Pauly
VCDS User
Admin
Moderator
I fitted a genuine westfalia detachable towbar and wiring kit to my 2022 6.1 when i first got it, never really used the towbar until recently and now found that disconnecting the trailer while the van is locked does not set off the alarm !
The trailer in question is a large modern car transporter, i understand that this function may not work with LED lamps and although the side marker lights are all LED the rear clusters are all filament lamps for side lights/brake lights/indicators/reverse/foglight
All lighting functions work perfectly on the trailer, i get the trailer symbol on the headunit when connected, the dash shows the extra indicator symbol and the foglight on the van is disabled when trailer is connected so as far as i can tell all other functions are working 100%
I have double checked all the coding and in particular looked at the 09BCM but dont see anything untoward there and not sure how to troubleshoot it ?
Do you have changed the BCM channel below to active?
ENG148492-ENG123016-Anti-theft protection-Diebstahlschutz_mit_Anhaengeractive
[EDIT:]
Possibly another one to change to installed?
ENG122979-MAS01374-Networking-Trailerinstalled
Just to follow up on this it is all working now
I thought i had checked and double checked all the coding and adaption options but the one listed above was set to inactive, changed to active and all good
Thanks to @mmi as always for the info
Hi is this possible to get working with a PF Jones kit it is the 6.1 version of electrics I have set with vcds parking sensors deactivate trailer displayed on radio. Am I just missing a tick box. Looked at above setting and it is deactivate when I activate I get a message this appears to be an uninitialized control module
