Hi all... Bit of an odd one which I'm not sure if anyone else has experienced.
Earlier this year I fitted autovox V5 pro which is a great addition to a converted van like mine with an obsructed rear window. Anyway I wired this up using the option of the additional 12v wire at the camera end that taps directly into the reverse wire of the rear light. This then changes the viewing angle on the screen when you select reverse.
Anyway all was woking fine until I recently upgraded my rear lights to the T6.1 style. These come with 2 modules per side which I believe are to do with the fact the T6.1 rear lights have dual reverse and fog lights?
Now there seems to be an intermittent signal being sent that is causing the screen to flick between a normal image and reverse image at random which is both annoying and distracting.
Is there anyway I can rectify this?
Many thanks
Many thanks
