T6.1 Shuttle Sliding Door Card Removal
campz
Hi,
I've searched quite a bit on this and struggling to find an answer or diagram... The slider cards are the last thing I need to get off the van to I can insulate, from what I can find there is a T20 that needs to be removed and then is it a case of brute force to get the cards off.
Any advice welcome, thanks!
If the 6.1 is the same as the 6 then theres a torx behind the handle. Then like you said brute force to remove the lower panel (you dont have to take the top off)
If you get stuck I have some pix somewhere. Dont do what I did and put too much stuffing in as it was force the doorcard out and foul on your paintwork!!
