Assuming that your TPMS is indirect and works via ABS system to go for direct TPMS you would need to install 5 pieces of hardware (4 pressure sensors/transmitters, one for each wheel & one common receiver connected to the CAN bus).Hi
I just bought a new Transporter T6.1.
Of course, the car has TPMS, but not with direct reading of what the pressure is in each wheel, in the display.
Is it possible to code it to display it with VSDS connectors, or do you need extra hardware?
- Mads
Hi - I want to so this with a set of 18” Tolucas I have just aquired for my T6.1. Can I ask where you ordered your TPMS valves from and do you have a part number? VW have quoted me £273 each which is obviously taking the proverbial. Thanks, Graham@SteH I have 19s on my 6.1 with direct TPMS. You need to have a set of TMPS valves fitted on the Cantera alloys. I ordered a set of TMPS valves I think they were around £40 each. Or if you don't plan on using the original wheels you can get the TPMS valves swapped.
You'll have various wheel / tyre options available on your media system, I just use the 18" variant as its the closest pressure I was recommend to use. Once you've driven a short distance the van will pick up the new sensors and display the pressure value.
Cheers Adam - thanks for the quick response. Is that Schrader part number the exact match for the OEM VW ones? Dont suppose it matters as long as it works but there seem to be millions of these valves available with small part number variations. Thanks Graham@GrahamB I bought mine through this website, https://www.piecesauto24.com/schrader/15410807 about €40 each (exc VAT).
Sorry its a French website but the part I used was:-
Schrader 2200B-GO1
You can get them in black or silver.
Adam
I don't think they are the exact match for OEM but they worked fine.
I had the same dilemma but I saw a photo on a post from @racerke600 and was able to read the part number. I dropped him a message and he confirmed they worked. It was still a relief to see them working though !
If its a T6.1 I am pretty sure how to activate the indirect has not been worked out yet. Im still trying to find that info. The direct with tyre pressure sensors in the valves is an option unlikely to have been added on a startline, but you could tell by looking at the valves. If they are the normal rubber ones you dont have it.Can anyone give me a definitive answer my brand new converted campervan I can’t seem to find in the menu tyre pressure monitor settings. It was when new a Startline panel van prior to its conversion.
I have searched a bit on here and I think it was a paid option needing activating , is this correct or am I just missing it somewhere?
You will need someone with ODIS or VCP software to do this for you,
