T6.1 traffic sign recognition retrofit?
Also interested in this...
T6.1 uses Front Assist camera MFK3.0 [2Q0980653B] which supports Traffic Sign Recognition (TSR or VZE), however the coding process is different to earlier 3Q0 / MFK2.0 as it is now a SWaP.
It's available for T6.1 from factory in supported countries as optional extra PR-QR9, however I'm not sure if a genuine retrofit part number is available?
For example some Audi models use the same camera and have available part "Activation document for traffic sign recognition" [8W0054800B] which can be purchased (for 99-400 GBP) and used to generate the FeC codes in ODIS. I'm not sure if that same part would work or alternative is available for T6.1. @Pauly ?
The alternative is to "obtain" a FeC code (using your VCRN/VCN), however I'm yet to find a trustworthy source?
Others have successfully retrofitted MFK3.0 with VZE after somehow obtaining the FeC:
Travel Assist или Установка камеры ассистентов нового поколения. MFK3 2Q0 — Volkswagen Golf Variant, 1.5 л., 2018 года на DRIVE2
ciclo. Wife's Golf MK7.5 Ready2Go 1.0 TSI 6MT 200Nm/l 115HP. First and Last pages UPDATED !!! - Page 40 - UK-POLOS.NET - THE VW Polo Forum
The available FeC codes for MQB_MFK3.0 2Q0980653 are:
100E1000Lane AssistV03.959.806.DH
100E1100(Navigation FEC)
100E1200(Navigation FEC)
100E1300(Navigation FEC)
100E1400(Navigation FEC)
100E1500(Navigation FEC)
100E1600Stationary object detectionV03.959.806.DR
100E1700Pedestrian detection (FCPW)V03.959.806.DS
100E0F00Traffic Sign Recognition (TSR/VZE)V03.959.805.CM
pACC which apparently relies on VZE can then be coded with a SWaP generator and the rest of the coding's & parametrics such as TJA are all currently available:
@LUNGU RAZVAN did you code pACC / TSR or was it stock?
