T6.1 washer pump fuse
tommy_t6.1
Builder
My washer pump isn't currently working. I thought it was due to no fluid, but the low level warning wasn't on and when I topped it up I barely had to put any in.
Does anyone know which fuse supplies the pump? I've gone through all the wiring diagrams on here and can't seem to find one associated with the washer pump.
Also, as its most likely the case, does anyone know the pumps part no. in case i need to order a new one?
I didn't think to scan it! Doh! Haha
I'll scan it tonight and see what comes up.
So there's no independent fuse for the washer pump then?
V59 Washer pump is fed directly from the BCM. Do you have any fault codes?
Hi there , I e got the same situation , on my t6.1 , wipers work washers don’t no motor sound at all .
The van is brand new and had a glass tail gate but was removed for solid tail gate by the conversion company , so would this steer towards the washer pump needing to be revised due to them removing the rear wipers and washer ¯\_(ツ)_/¯¯\_(ツ)_/¯
Thanks in advance
Ash
