Hello all, I have a 2017 T6 California Ocean and have been battling with the aircon for some time. I would love to get it fixed. The problem started with the AC apparently not giving cool air.
I started by having it re-gassed but that did not solve the problem, but after further investigation and looking for fault codes, I noted that the rear zone is working OK, but not in the front. This indicates that everything is fine on the cooling front, but that there is a routing / flaps problem with getting the cold air to the front vents. I've tried re-setting the flaps multiple times by holding down the AC and front vent buttons but that doesn't do it. There are no relevant fault codes.
I do have an OBDEleven device so should be able to do some detailed diagnostics of flap angles if there is anyone out there that knows what they should be?
Thanks in advance ... Nick.
