Hi all wise ones.
My current problem is as the title says. I have a 68 plate, Caravelle executive and have up grades the lights with THQ V3 lights some years ago. No problems until the other week or so. The V3 lights have LED main lights and standard Main beam H1’s fitted.
I noticed a little while back that when I put main beam on the ‘light out’ symbol came on on the dash, easy I thought, the main beam bulb has gone. Sure enough the near side didnt work so I changed the bulb. However the fault remained and every time I start the next journey and used the flash or put main beam on the symbol came one and I only had the off side working. I checked the vehicle main loom to THQ lights and I have 12v pos coming from the van to the back of the bulb. Is the black wire to earth or does it go via a sense feed (possible CAN bus)? I can’t find a wiring diagram on google so flying blind at the momen.
I have spoken to Chris at THQ and he has been honest and said that he is limited in his tech knowledge but has also said that it may be related to the tow bar (VW factory fit) or the reverse camera (I’ve fitted this into my standard head unit, with so far no problems)
Can any one advise possible problems that I can go to? I.E. where the OEM tow bar can be disconnected to remove for faultfinding?
Thanks in advance.
Thanks in advance.
