T6 Caravelle rear quarter trim removal
I need to remove the rear trim on both sides of my 2016 Caravelle so that I can do some rewiring. I've removed the top pieces if trim on the C and D pillars but don't know how to remove the large pieces of lower trim. Just pulling doesn't seem to do it but should I use more force or are there some hidden screws? Its this big piece of trim running from the side sliding door all the way to the tailgate that I want to lift offIMG_1117.jpeg
This may help as the panels are similar:
Failing that, look up @StudleyGlass’s Kombi to Caravelle build thread
As mention in the thread Ads tagged, its just a matter of a bit of careful force to release the hidden clips that are clipped into the panels behind
if you look at the picture below you can see 3 of the black clips on the lower c -pillars . There are a few more dotted across the panel, also one on the center of the lower arch as in the picture.
I need to remove the rear trim on both sides of my 2016 Caravelle so that I can do some rewiring. I've removed the top pieces if trim on the C and D pillars but don't know how to remove the large pieces of lower trim. Just pulling doesn't seem to do it but should I use more force or are there some hidden screws? Its this big piece of trim running from the side sliding door all the way to the tailgate that I want to lift offView attachment 81548
Hi Richard. Trying to remove just the cup holder and charger binnacle and wondered if you saw how it was fixed to the panel? I have looked everywhere for advice how to detach it from the bottom of the C pillar to no avail. Many thanks in hope.
