Yes I cant see what possible improvement that will give you, the Caravelle is the same underneath but the springs are slightly different to allow 20 mm lower ride height ( SWB only ).
This won’t improve ride at all and, if fitting in an empty van, might not lower it as the Caravelle seating and interior is a lot heavier and the springs allow for this.
The bump stops on the front shocks are also shorter, so again, no real gain there.
