T6 Gearbox Mount
LeeCor
Looking for some advise on changing the gearbox mount. I have just been trying to change it but I couldnt get the top left bolt out cicled in the photo. I lowered the gearbox down slightly but It wouldn't go down enough to gain access to the bolt. It looks like either the subframe has to be lowered or removed so the box can be dropped enough to gain access of the bolt.
Wondering if there is another way or if anyone has changed this before?
Is there a hole for the purpose through the chassis under that cover? ( I don't know, just a thought )
Good shout, I didn't look if honest, will certainly check. I think it might be wishful thinking though.
I’ve had this mount off twice now…
Both times I had the subframe out and lowered the gearbox.
You may not have to remove the subframe completely, but certainly lower it slightly.
