Do you have High beam assist switched on?Hi hope someone can help 2016 T6 dip beam works high beam pass working high beam works if you hold the stalk down but as soon as it’s released it’s back to dip
The stalk is only a momentary push so it would be a controller issue.Ok if we assume it hasn’t got assist do I need to get someone to run diagnostics or could it be the stalk?
Hi Marcp,Hi Sounds like the switch will be ok I'm going to look at it tomorrow are there and pin tests I can do as it sounds like the relay is not staying over or that the controller is not holding the relay ?? any info to what I need to test /check would be much appreciated
Hi, Pauly, it is , as probably all the same issue.. if I hadn’t just driven 9 hours I’d investigate it a bitShame none of the above posters ever came back with findings/resolutions
What position is the light switch in?Interesting , just picked up a T6 from Holland . No main beam. Flashes ok (blue light) but no main beam tried everything , just reading this thread. Will try the in Auto position and stalk push twice see if I have high assist not convinced but hopeful
or any suggestions other than VW dealer ?
I have tried auto , and on to the right… vans having its control now so I can import to France. Hope it passes, will have another look later .What position is the light switch in?
Ok thanks , will do..Try a simple BCU reset first by disconnecting the starter battery for a minute.
No luck on Re set..Ok thanks , will do..
That’s a bit technical for Friday . standard as far as I know .. 2018 T6 panel .Are your headlights LED, H7 or H4?
